ipsec vpn
2023-02-03提问
  • 0收藏,747浏览
做了个实验,用的是野蛮模式,右边分支自动获取地址,第一阶段ike sa有,第二阶段ipsec sa看不到,之前做了很多次,我自认为我的配置没有问题,大佬帮我看看
粉丝:9人 关注:6人
你的acl没有匹配内网地址。需要双方私网地址ping一下,去触发隧道
6 个回答
子升 知了小白
所以,你的配置呢?
# version 7.1.064, Release 0427P22 # sysname R2 # system-working-mode standard xbar load-single password-recovery enable lpu-type f-series # vlan 1 # interface Serial1/0 # interface Serial2/0 # interface Serial3/0 # interface Serial4/0 # interface NULL0 # interface GigabitEthernet0/0 port link-mode route combo enable copper ip address dhcp-alloc ipsec apply policy 1 # interface GigabitEthernet0/1 port link-mode route combo enable copper # interface GigabitEthernet0/2 port link-mode route combo enable copper # interface GigabitEthernet5/0 port link-mode route combo enable copper # interface GigabitEthernet5/1 port link-mode route combo enable copper # interface GigabitEthernet6/0 port link-mode route combo enable copper # interface GigabitEthernet6/1 port link-mode route combo enable copper # scheduler logfile size 16 # line class aux user-role network-operator # line class console user-role network-admin # line class tty user-role network-operator # line class vty user-role network-operator # line aux 0 user-role network-operator # line con 0 user-role network-admin # line vty 0 63 user-role network-operator # acl advanced 3000 rule 0 permit ip source 20.0.0.0 0.0.0.255 destination 10.0.0.0 0.0.0.255 # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # ipsec transform-set 1 esp encryption-algorithm des-cbc esp authentication-algorithm md5 # ipsec policy 1 1 isakmp transform-set 1 security acl 3000 remote-address 10.0.0.1 ike-profile 1 # ike identity fqdn R2 # ike profile 1 keychain 1 exchange-mode aggressive local-identity fqdn R2 match remote identity fqdn R1 proposal 1 # ike proposal 1 # ike keychain 1 pre-shared-key address 10.0.0.1 255.255.255.255 key cipher $c$3$gwtIvSkM9K8BbsyopfIWDI3Rbj2Twg== # return
半步硕士 发表时间:2023-02-03 更多>>
发了附件呀
有个IE梦 发表时间:2023-02-03
总部
[R1]display current-configuration
sysname R1
xbar load-single
lpu-type f-series
vlan 1
interface Serial1/0
interface Serial2/0
interface Serial3/0
interface Serial4/0
interface NULL0
combo enable copper
ip address 10.0.0.1 255.255.255.0
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
combo enable copper
line class aux
line class console
line class tty
line class vty
line aux 0
line con 0
line vty 0 63
acl advanced 3000
rule 0 permit ip source 10.0.0.0 0.0.0.255 destination 20.0.0.0 0.0.0.255
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
ipsec policy-template 1 1
transform-set 1
security acl 3000
ike-profile 1
ipsec policy 1 1 isakmp template 1
ike identity fqdn R1
ike profile 1
keychain 1
local-identity fqdn R1
match remote identity fqdn R2
proposal 1
ike proposal 1
ike keychain 1
pre-shared-key hostname R2 key cipher $c$3$ctKB8aqTOBmPqa7wr33z4yl9BW9M9Q==
return
分支
分支 # version 7.1.064, Release 0427P22 # sysname R2 # system-working-mode standard xbar load-single password-recovery enable lpu-type f-series # vlan 1 # interface Serial1/0 # interface Serial2/0 # interface Serial3/0 # interface Serial4/0 # interface NULL0 # interface GigabitEthernet0/0 port link-mode route combo enable copper ip address dhcp-alloc ipsec apply policy 1 # interface GigabitEthernet0/1 port link-mode route combo enable copper # interface GigabitEthernet0/2 port link-mode route combo enable copper # interface GigabitEthernet5/0 port link-mode route combo enable copper # interface GigabitEthernet5/1 port link-mode route combo enable copper # interface GigabitEthernet6/0 port link-mode route combo enable copper # interface GigabitEthernet6/1 port link-mode route combo enable copper # scheduler logfile size 16 # line class aux user-role network-operator # line class console user-role network-admin # line class tty user-role network-operator # line class vty user-role network-operator # line aux 0 user-role network-operator # line con 0 user-role network-admin # line vty 0 63 user-role network-operator # acl advanced 3000 rule 0 permit ip source 20.0.0.0 0.0.0.255 destination 10.0.0.0 0.0.0.255 # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # ipsec transform-set 1 esp encryption-algorithm des-cbc esp authentication-algorithm md5 # ipsec policy 1 1 isakmp transform-set 1 security acl 3000 remote-address 10.0.0.1 ike-profile 1 # ike identity fqdn R2 # ike profile 1 keychain 1 exchange-mode aggressive local-identity fqdn R2 match remote identity fqdn R1 proposal 1 # ike proposal 1 # ike keychain 1 pre-shared-key address 10.0.0.1 255.255.255.255 key cipher $c$3$gwtIvSkM9K8BbsyopfIWDI3Rbj2Twg== # return
粉丝:117人 关注:8人
配置如果没问题的话 把设备内存调整到512
ipsec排错,参考:
IPSEC排错点穴神功
子升 知了小白
ACL应该是针对内网保护流ip做的
粉丝:165人 关注:1人
直接开debug
粉丝:35人 关注:7人
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec  transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec  transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display  ike proposal
6、display  ipsec  transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
